ABS light constantly on 1.9TD 1998 Xantia please help
shaunlfc1
Unread post by shaunlfc1 »
Hi all,
The ABS light will not go out on my xantia, the brakes still seem to work fine, but I am assuming one of the sensors is faulty. How do find out which one it is without having to replace them all?
I will check the obvious "sh*t " on the sensors but I am not that lucky. So if there anyway of knowing or testing each sensor?
Cheers all,
Shaun
spider
x 77
Unread post by spider »
I think a Lexia or earlier diag will tell which sensor.
Check the multiplugs too, on both the ABS unit and each sensor (usually a few inches away from the sensor there's a plug) for corrosion / damage etc.
Andy.
VertVega
x 13
Re: ABS light constantly on 1.9TD 1998 Xantia please help
Unread post by VertVega »
shaunlfc1 wrote:The ABS light will not go out on my Xantia, the brakes still seem to work fine, ... So if there anyway of knowing or testing each sensor?
Easy and quick solution would be to measure resistances with a multimeter.
Pins are shown in this thread ---> Xantia ABS Sensor
First pic for MK1
Second pic for MK2
