Advice Sought RE: Downloading AL4 Update
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Xsara II with EW10J4
In the download files list there is one to install when the electrovalves are swapped.
Do I need any security codes to implement the download? How long does it take, typically?
Will be making sure the car battery is charged, also that laptop battery is good and I'll even have the portable generator handy for continuity of power...
Thanks, Adam.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I managed to successfully get an update downloaded onto my V6 (now Jim's) whereas every other time I've attempted it on other cars its failed and that's using a genuine Citroen Lexia.
One thing to bear in mind is that I recently had an interesting conversation with a technician at Citroens Slough HQ on this very subject, his opinion was to avoid downloading unless absolutely necessary as it comes with the serious risk of messing up the ECU to the extent that a new one may be required should it go wrong,,,,,,,
As far as the procedure it was simply follow the idiot proof instructions, IIRC it took no more than 10 minutes and no codes required.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1056
Unread post by wheeler »
Pretty much agree with what Dickie G said. There is alwaya a risk when downloading any ECU (even with a genuine lexia). Although ECU crashes are quite rare if your careful enough it should only be done if necessary, in this case i'd say its necessary as the new gearbox electrovalves are pretty pointless without the right software for them.
Its a good idea to either have a good battery charger on the car or another car with jump leads & the engine running. Lexia will tell you that anyway in the warning screens.
Just make sure that no one trips over the lexia lead while its downloading :twisted:
addo
x 95
Thank you both; will observe all recommendations. I'm starting to like Xsaras - it's amazing how many niggles you can squeeze into one small car. (This being the fourth problematic facelift Xsara...)
wheeler wrote:Just make sure that no one trips over the lexia lead while its downloading :twisted:
That would be an expensive trip! I'm still smarting from a contingent liability claim that will top £8500 and doesn't meet insurance criteria. :x
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi Addo
I have a Xantia and a Lexia 3 can you please let me know where these download files can be found ? Are these files part of the Lexia 3 software ?
Zohar
