C5 Lexia questions
Allanxantia
C5 Lexia questions
Unread post by Allanxantia »
DHallworth has been helping me play around on the lexia to get rid of this annoying economy mode problem.
In the lexia menu it staes that economy mode is set to 30m however I want to try changing it but it is asking for a code? any ideas what code this is?
Also I hoped we could turn off the wheel pressure sensors, any ideas how we do this?
Thanks in advance
2002 C5 V6 Exclusive auto LPG
1997 Xantia TD SX £200 bargain
1993 Xantia DLX (now dead)
Then after a 10 year Citroenless gap
1995N Xantia Activa
KevMayer
Unread post by KevMayer »
The code is probably a four figure code which came with your C5 on a plastic credit card.
My code is 450G. It hadto be used once when I had the BSI software updated.
I believe that a main dealer can find out what it should be for a fee.
Cheers, Kev
DHallworth
x 162
Unread post by DHallworth »
Why would the cars economy mode timer be set to 30 minutes but the car entering economy mode instantly?
Seems strange to me!
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
Allanxantia
searched everywhere don't have the code. just spent an hour pulling potentially suspect fuses (alarm, radio) one at a time to check for any stray current drains, and nothing.
1995N Xantia Activa
wright
Unread post by wright »
the code is 03114, the wheel sensors is in the accessories menu i think
02 C5 2.0 hdi 110
Allanxantia
thanks, we tried the wheel sensors, we could find the reference pressure setting and a setting from memory to set them as "present" or "missing" to no avail, made no difference.
On the plus side with all the fault codes cleared, the car felt better and smoother
1995N Xantia Activa
DHallworth
x 162
Thanks wright, is that a generic code for them all?
Allan, the problem was that we couldn't write the settings to the BSI after we'd disabled the tyre pressure sensors or changed the economy mode setting as we didn't have that code.
Be worth trying again.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
wright
it is, and you will only need to put it in once, usually, the code that comes on a card when new is an individual code and is needed for coding new keys and i think bsi units
02 C5 2.0 hdi 110
x 94
Unread post by citronut »
my dealere gets the card 4 digit code free of charge these days, im not sure if they will for the general public though,
also i think the code can be got from service citroen with the chassis/VIN No. somehow,
regards malcolm
The Birdman
Unread post by The Birdman »
citronut wrote:my dealere gets the card 4 digit code free of charge these days, im not sure if they will for the general public though,
also i think the code can be got from service Citroën with the chassis/VIN No. somehow,
regards malcolm
Dealers here charge £18 for the Transponder code (i think they all phone the main headquarters in Coventry), you can get it from service box but not the free online part , you will need "user name" and "password" for that area :wink:
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
Allanxantia
So, is it 03114 as wright says or do I need the code, incidentally I found the card but all sections are blank, it was a citroen UK car originally so possibly not the most thorough PDI
1995N Xantia Activa
MikeT
x 232
Unread post by MikeT »
If any long-standing members needs their Keycode, PM me the VIN and I can usually get it within a day or two for you.
If anyone knows how to get them from Service Box, let me know as I should be getting full access shortly as well.
The Birdman
MikeT wrote:If any long-standing members needs their Keycode, PM me the VIN and I can usually get it within a day or two for you.
To get them from service box you need password and user name for the confidential part , just having full access does not guarantee Transponder codes part of service box. ( i have access) :wink:
MikeT
x 232
Sorry, can you elaborate on what you mean by password and user name for the confidential part? What I meant by full access was to all areas of the system, including those areas that require payment.
Thanks for confirming the keycodes can be had through service box. Care to share which section I need to go to? :)
The Birdman
Incidents and Solutions :)
