p reg synergie fuel priming
dave2011
hi all.ive heard that there is a pre fuel primer on a 1.9td that primes the fuel before it starts..........as mine dont work n i have to prime the car 1st thing on a morning which is a pain i was wondering if any1 knows where its located on the engine n why it would pack up?...... cheers guys
- x 5689
It is the rubber bulb in the fuel line on the left hand side of the engine bay, squeeze it 'til it gets hard and the engine should fire straight away.
There is likely a leak somewhere in the fuel line, overnight the fuel partially drains away and is replaced by air.
The usual trick is to replace the fuel line between the primer bulb and the pump with some clear fuel line and look for bubbles that will confirm a leak, then hunt down where the leak is.
Very often it is hardened and cracked leakoff pipes or the end cap missing from them.
dave2011
- x 5689
dave2011
is the pump that easy to seal up?....... ive been quoted 100 quid to seal it up n it would have to be removed.
im guessing the pump in the tank is ok as it runs fine once its started.......its just gotta be primed on a morning.
i,ll have a search n see if i can find owt on sealing the pump up.cheers.
