Xantia clutch change
froggy
- (Donor 2026)
- x 4
Hi , is it a difficult job to change my clutch in my 1997 td Xantia .
Any help greatfully received
cheers Terry
cheers Terry
P616VKX
- x 8437
froggy
- (Donor 2026)
- x 4
Cheers Jim , your a star !
Terry
Terry
VertVega
- x 13
ThanksCitroJim wrote:... Here's the full guide
Edit: How many miles does it 'normally' take for a clutch change?
- x 8437
I think it depends entirely on how the clutch is used VertVega although they do seem to last pretty well. Off times it is the fact that the clutch is getting very heavy in operation that propmpst a change rather than the clutch itself slipping.VertVega wrote: Edit: How many miles does it 'normally' take for a clutch change?
It's a strange quirk that these 'pull' clutches get heavier in operation as they wear. The lightness of a new clutch is almost unbelievable...
Xantidote
- x 4
flying clutchman
- x 3
citroenxm
- Fallen Hero
- x 70
Yes - these pins ARE either a breeze to pull out, or an absolute T_*$T to come out....flying clutchman wrote:The hardest part of getting the box out of these is trying to get the pin out of the clutch arm when it has'nt been touched in years.
The box DOES NOT have to come complete out at all, once you get the gearbox mount spigot out the way, the box when lowered to a comfortable level moves away enough to get the clutch plate and friction plate out... you may need to move it forward slightly to get the alignment tool in.. I happen to have a "Proper" BE Gearbox input shaft for alinment...
However, ML gearbox's in the HDi 110bhp cars are bigger, and theres less room, also the input shaft is bigger so my alinment tool is no good...
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
flying clutchman
- x 3
citroenxm
- Fallen Hero
- x 70
WOT!! NOT a heavy BOX!! You must be like Arnold schwarzenegger!!
The ML box is Bloody heavy, and defeantly heavyer then the BE box in the Xantia, which is still a heavy box...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
flying clutchman
- x 3
DickieG
- Monaco's youngest playboy
- x 33
One "trick" used in the trade to assist re-assembly in ensuring the clutch fork is correctly located onto the thrust bearing is to punch a hole in the underside of the bell-housing for observation purposes, not ideal but it could save some frustration.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
jgra1
- (Donor 2021)
- x 36
ACTIVE8
- x 6
Re: Xantia clutch change
So what sort of job is this clutch change on the various models of Xantia I.E. in respect of job time (hours) in a workshop, or job time (hours) at home when not having the extra facilities of a workshop I.E. a two post ramp.
I would be interested to find out the information in respect of the models listed below.
(1)T.D
(2) H.D.I.
(3) Activa
(4) V6
Note I have read through this thread, and the connected thread, and links so I appreciate it is a long job, and not easy.
The thing that was missing amongst the very informative, and useful details was a note of how many hours it takes to do.
Thank you to all that answered the threads I mentioned as they made for great reading.
(1)T.D
(2) H.D.I.
(3) Activa
(4) V6
ACTIVA
