Hi all. I have a well worn 2.0 HDi Xantia 177K on the clock. It goes well.
There is a rattle from the front suspension when on rough roads. I can`t find anything worn or loose. The car recently went through the NCT ( Irish MOT )
in which they give the suspension a good going over and they had no comments. It sounds like it could be coming from the front struts. The ride is good and the handling doesn`t feel loose. Any ideas ? ....rgds dannyboy
Rattle from front suspension...Xantia 2 2.0 HDI
- DickieG
- Monaco's youngest playboy
- x 38
It'll be either from one of the ball joints, anti-roll bar or bottom ball joint being the favourites failing that if its a 110 bhp model it could be the front brake calipers rattling on the mounting brackets, try gently pulling up the handbrake whenever the noise appears, if that stops the noise then you can eliminate it by fitting additional springs behind the calipers to brace them.
13 Ram 1500 Hemi
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
14 BMW 535D Tourer
19 BMW i3s
06 C3 Desire 1.4
Almost definitely one or both anti-roll bar drop links. You might as well replace both at the same time though.
Now using '00 Xantia LX HDI, pov spec
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident
'99 Xantia HDI 110 Exclusive, RIP
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped )
& a couple of Peugeots !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
front suspension rattle
I had checked out all suggestions......couldn`t find anything...........the rattle had gotten worse so had another look..........now I can feel play in the drop links ! I gave them a good pulling about the last time and found no disernable play......there is now !........will replace them the next service...........rgds....Dannyboy.
