Hydraulic pump rebuild
davewithington
Unread post by davewithington »
As part of the planned maintenance/ rolling rebuild of the Xantia, i'm looking to refurbish the pump. I suspect output pressure is down and it leaks - not much but enough - which is probably the big o-ring behind the cover.
Anyone rebuilt a pump?
Anybody got a VSX pump I can have for rebuilding? I like to have spare bits so I don't have to take the car off the road, though my 2CV should be back on the road this month which takes the pressure off somewhat.
VSX sinker 1.9TD
andmcit
x 30
Unread post by andmcit »
Sinker pump?
I've never seen another going spare so rarer than an honest politician =
best of luck getting one - the pump design is predominatly the same with
the later ones although the drive pulley and main body/end bowl will need
to be carefully referenced. I'll try and find some pictures I've got of one I
took apart. Likely it's the o rings/seals but the main pump body should be
fine; the whole assembly has through bolts that can actually fatigue and snap
if the pump has been working for some time with poor accumulator sphere.
Andrew
davewithington
I replaced the accumulator sphere about 14months/10000 miles ago, so should be OK.
x 8466
andmcit wrote:Sinker pump?
As you say Andrew, but they are rarer than that even. They are rarer than an easy, straightforward job on an Activa :twisted:
Now I actually have one but it's in use and I'd be lost without it... It's the pump on my sphere tester..
Now, if I could replace it with a single outlet pump from a CX, BX or early XM then I'd be happy to part with it.
That's the best I can do...
davewithington
I might just have a BX pump......
I'll let you know
