Hi all
i am going to need to do a headgasket on an xud due to water in the oil.... However. The gasket has got 2 notches then just seperated by a larger edge 3 notches... They are NOT all grouped together before you all shout and tell me its a 5 notch. So my q is, is it a 2 notch or a 3 notch gasket????
Im guessing a 3 notch meaning i look at the notches along the centre line...
paul
XUD Headgasket type
citroenxm
- Fallen Hero
- x 70
XUD Headgasket type
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1240
Chlorate
According to my BoL the thickness notches are located to one corner of the gasket.
Coolant in the oil is possibly a bad sign though. Not that I'm doubting your experience Paul, but when I discovered my HG had gone we called Triple A Citroen and their first question was "is it just losing water, no water in the oil?" apparently they reckoned coolant in the oil was a sign the head has cracked
Although my head was cracked to buggery and there was no mayonnaise in the sump....
Alex
Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police
previously:
MikeT
- x 232
citroenxm
- Fallen Hero
- x 70
Peter.
The xantia laminated gasket still needs to be a thickness size on the xantia... One size wont do all...
Chlorte. Im hopeing its gasket and not head... As i aint got another known good head...
Mike. I tried google-ing head gasket but kept gettin crap results. I didnt try psa head gaskets though.... Doh...
Cheers
Cheers
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
spider
- x 77
- x 1479
citroenxm
- Fallen Hero
- x 70
Ah, now thats conflicting Richard...
As the PDF mentioned above shows the top two notches are the thickness, and the bottom 3 are engine ID....
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1479
- x 1240
Hi Paul
Just consulted Mr Haynes : D8B engine (XUD9 TF) I think that's yours it says : piston projection 0.54-0.65, 1 notch, 0.65-0.77, 2 notches, 0.77-0.82, 3 notches. If the gasket has another three notches, disregard them.
This doesn't really help a lot though as you have taken the metal off the head not the block. If you set the valves open and see where the heads come to in relation to the surface of the head I'm sure you will find you have sufficient clearance, to be certain check the piston projection as well.
I remember once fitting to thin a gasket to a Perkins engine with the result that it would start without heating - unheard of in those days but the valves still missed the pistons
