Pug 306 HDI won't start ?
HDI
x 7
Unread post by HDI »
Although this is a Pug question, it's the same engine as Citroen so I'll ask here first.
Friend's car, won't start, Cranks ok, there is fuel pressure. Are there any known common issues for this ?
He doesn't have a code reader handy but is trying to get hold of one to use.
Where is the CPS on these ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
spider
x 77
Unread post by spider »
TDC Sensor is the first thing to check then if you have fuel pressure as if you did not have FP then I'd say the LP pump in the tank.
It should be either on the top / side of the transmission as it has to 'see' the flywheel really, or on some later engines (perhaps only the 1.4HDi) its near the crank pulley.
I have not looked at one for about five years, but its got to be in either of those places.
Andy.
mickeybo
306 non runner
Unread post by mickeybo »
Engine code would be a good start Regards Mickeybo
The Birdman
Unread post by The Birdman »
Any immobiliser lights , anything happen to it prior not starting , bad battery or alternator , some history would be nice.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
DHallworth
x 163
Unread post by DHallworth »
The 306 HDi has an immobiliser but it's controlled totally by the remote locking fob and doesn't show any lights in the car.
Although you say the engine is cranking fine, try jump leads to a running car or a different "good" battery. I've had this on a couple of 306 HDi's where they sound like they should fire but because the battery voltage isn't quite right it wouldn't fire.
When I plugged a good battery in she fired straight away.
David.
'98 Xantia Activa V6 :-D
'00 XM V6 Exclusive
'09 C5 2.7 HDi Exclusive
‘10 C5 3.0 HDi Exclusive
'12 C6 3.0 HDi Exclusive
'15 C4 BlueHDi Feel
