Xantia switch faulty ?
froggy
(Donor 2026)
x 4
Unread post by froggy »
Hi, The sliding switch on my heater blower has finally decided to stop .
It has been intermitant for weeks ! is this an easy fix ?
cheers Terry
x 1506
Is the slider jammed, or the blower no longer responding? What's the blower doing? Failure of the control transistors or the ignition switch is much more likely....
froggy
(Donor 2026)
x 4
Hi, the switch works , slides ok and I have replaced the blower motor, but I don"t have any power . fuses are ok .
Thanks Terry . p.s. It"s a 1997 Xantia
Clogzz
x 40
Unread post by Clogzz »
Usually the ignition switch.
Later cars have a factory modification with relay to take the blower current off the switch.
Modification topic here:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=21372
