Hi Im trying to put a xud9 td engine into a peugeout j5
the j5 had a push clutch , however the xud9 engine i have has a pull type clutch, can i just fit a j5 clutch kit to the xud flywheel?
the engine is out of a 406
are push /pull clutches interchangeable????
spider
- x 77
the jester
spider
- x 77
Later turbo diesels usually.
306TD newer shape (late 96 on) , not DW8 usually.
All 406 1.9TD's
You do mean the 'slightly annoying' one where the bearing is part of the clutch itself yes ? , in which case my list is correct.
All 406 1.9TD's
Andy.
spider
- x 77
