Has anyone had any experience of this problem? Reservoir low and LDS dripping down near side wheel arch.
Few questions:
Will it just get worse or can i just keep topping it up?
Has it got to be seals or could vibration have lossened the union nuts?
If all the LDS runs out will it bugger up a pump?
How much does a new rack cost or is a refurbished one a better option?
How much time should the job take? (I may need to use an independant garage for this one)
All advice greatfully received...
Leaking Steering Rack on C5 (HDI 2LT 2001 110)
addo
- Sara Watson's Stalker
- x 95
Jeff
addo
- x 95
Jeff
addo
- x 95
On a hoist, for sure With two wheels up on the kerb and wriggling under - maybe. Be careful to ensure that if the car slumps it won't drop far enough to pin you under...
Look for a rubbery hose about 7/16" thick coming off the rack input shaft just near the universal joint, and slimy wet with hydraulic oil.
Jeff
Hi Adam,
Called into a garage today on way home, run by someone i know and was going to ask if car can go up on a ramp saturday morning (when i/m off work), to try to pinpoint source of leak.
I pointed out oil around wheel arch and straight away he said it was from the strut, the return pipe was split (so whenever the cars suspension lowered LDS fluid was lost).
He pulled off end bit and refixed the pipe 1 minute flat. I am hoping thats the end of this problem, which was very similar to what you suggested so thanks very much for your help.
Jeff
Old South Wales
Jeff
Old South Wales
- x 5689
Jeff
- x 5689
Jeff
