Xantia Exhaust Joints
Toby_HDi
x 3
Unread post by Toby_HDi »
Can anybody confirm how these are assembled correctly?
The centre box to cat joint is easy - it slides in and then is clamped. The rear joint appears to only be able to butt together, and the clamp holding them. This doesn't look right as there seems to be a section on the centre box for sliding the rear box in.
Clamps are a pain, I know I could go and buy some two piece clamps but I might just buy the tool for them. Makes it much easier in the future.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 1506
They just butt together - the fact that one is bell mouth and the other bulbous means I guess there is a degree of movement available when fitting it. I usually put a smear of exhuast paste on the joint to help it seal. The spring clips are a royal PITA, but I guess a hefty pair of circlip like pliers should do the business - I think Jim made a pair when he was working on a lot of V6s :lol: I junked the clip on our Picasso last week and fitted a two piece clamp instead - mind you that is no easy task - just getting the old clamp off nearly had me reaching for Mr Angle G Rinder :roll:
HDI
x 7
Unread post by HDI »
As standard it's a cone joint on the back box, if you have a slip joint it's the wrong part.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Toby_HDi
x 3
It has the cone, and the backbox butts up to it for the clamp to go over. Just didn't look right is all.
I'm pondering whether to just chuck the original clamps and get some two piece ones.
On top of that, I've noticed some LHM on the ground where it was stood whilst I did the exhaust, seems to be coming from the corners. Bloody typical!
Toby
Previous:
x 94
Unread post by citronut »
it is fine to use a two piece clamp at the rear box joint,
also i have used two thick long pin punch's to open the circle type clamps, one through each eye and both pointing outwards,
i have also noticed a new one is spread far enough appart to just drop straight over the two flandges,
as i have just fitted a new cat to my daughter Pisssscassssoooo
regards malcolm
Toby_HDi
x 3
citronut wrote: i have also noticed a new one is spread far enough appart to just drop straight over the two flandges,
Thats interesting Malcolm. Might just be worth getting a pair of new ones.
You didn't mention if the two piece clamp is suitable for the cat-centre joint. Any particular reason?
Toby
Previous:
Diabolical
Unread post by Diabolical »
I just replaced my back box using 2 piece clamp, fiddly but seems to have pulled it all together OK.
06 C5 2.0L HDi Exclusive Estate 20020k and rising. :-)
1987 Citroen CX Prestige. De Corps Brun Maya - cuir blond tabac, très chic
08 Jaguar X-Type 3.0V6 Sovereign Estate - Green (HGZ) - Leather Ivory seats.
citroencx.co.uk
x 94
i think the reason they use the ring type clamp on a cat, is the cat can get very hot and the ring type clamps are stainless steel,
also you should never use exhaust jointting paste/sealer forward of the cat,
aparently if it gets into the cat it can damage/destroy it,
i also preffer working with exhaust flandge type joints, far easyer the pipies which go inside pipes,
its all to do with the angle of the dangle,
regards malcolm
HDI
x 7
The cone type joint is way better than slip joints in my experience. Installing the clamp does have a bit a trick to it, a pry bar is your friend !
I've found that the cone joint will come apart even after being on the car for years, generally, a slip joint will rust solid and need cutting off.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Gingerposer
x 6
Unread post by Gingerposer »
HDI wrote:The cone type joint is way better than slip joints in my experience. Installing the clamp does have a bit a trick to it, a pry bar is your friend !
I'll second that - I recently had to replace the rear clamp on my exhaust - the exhaust itself shows no signs of corrosion but the clamp was just a mass of corroded metal. Replacement was a two hand and one knee job (knee used to brace the rear section in place while securing the clamp).
