C5 dual zone heating
the bish
Unread post by the bish »
Hi.
My 2007 c5 dual zone heating isn't working properly.
Drivers side is ok but passenger side only blows cold air.
Any idea what the problem is?
The Birdman
Unread post by The Birdman »
On Peugeot`s the fix is £1000 through dealer but there is meant to be a easier fix for it , the flaps on the directional unit break and have to be replaced, if i can find out more i`ll let you know.
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
KevMayer
Unread post by KevMayer »
Take a look at this thread:-
http://www.frenchcarforum.co.uk/forum/v ... ht=#241967
The problem is with the flap control motor. The original has a short spline which eventually chews up the hole in the shaft of the flap . A replacement motor can be fitted which has a long spline.
To fit it you need to remove the glove box and then it's easily reached.
Cheers, Kev
the bish
Thanks for the info guys.
