FAP REMOVAL
john alexander
FAP REMOVAL
Unread post by john alexander »
Hi If I remove the inside of the fap on my wifes 307 sw 1.6 05 plate, will it still go into limp mode or will it just keep on showing the faults on the display and the warning lights.
regards john.
spider
x 77
Unread post by spider »
Its quite likely to do both to be honest. It 'needs' it as the ECU program expects it to be there so it can measure the output as well as the input to the exhaust system.
Andy.
The Birdman
Unread post by The Birdman »
I have it done on my 407 , total cost for defap and remap was £300
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
john alexander
Hi can you tell us where you got it done, what actually did they do and how much of a difference has it made to your car. john,
The Birdman
john alexander wrote:Hi can you tell us where you got it done, what actually did they do and how much of a difference has it made to your car. john,
Battered out the inside of the FAP filter and put back on , remapped the ECU to de-fap and increase bhp and torque -
standard 180 lb ft of torque ,went to 280 lb ft
standard 110 bhp ,went to 146.6 bhp
Great torque through out gears and no flat spots
