Hi all..
Customer has a Xantia Estate with 1.9 XUD Turbo...
The oil has mixed with water and is quite messy, its not the head gasket as theres no cooling system pressure and the car runs far too well and smoothly so Im pretty certain its the Oil cooler..
My Q is, whats the best way of clearing out the old oil ready to put new in??
Drain, fill with cheap oil, drain then refill?? Or is there another way of dooing it??
Cheers
Paul
Cleaning out Emulsified Oil
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
addo
- Sara Watson's Stalker
- x 95
Hi Paul, the only problem with that diagnosis is - oil galleries run at a much higher pressure than the cooling system (50+PSI v. 14PSI). An oil cooler that's been impact damaged might leak, but generally the other direction due to the pressures described.
Could some numpty have put coolant in the oil filler?
citroenxm
- Fallen Hero
- x 70
No deffo not... It cant come from any were else, the gasket is fine..
I guess its worth bypassing the cooler, to try, but clearing the old stuff??
Would it work by putting old used oil through a few times? Ive got pleanty of that, then finishing with Fresh new oil...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Chris570
- x 36
personally if it was me i'd drain the old oil out, refill with some asda special or some such cheapy oil get the oil nice and hot then drain and swap filter and put good oil in. use the cheapy oil to pick up the crap, if it is a dirty system i'd change the filter twice.
just how i'd do it
just how i'd do it
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
citroenxm
- Fallen Hero
- x 70
HDI
- x 7
- x 5666
- x 1240
