I cannot get the main beam on, the dipped beam works and everything else works except the headlight flasher. I have checked and no fuse in the two fuse boxes is blown. I have had the bulbs changed and the high/main beam still does not work but the garage said they suspected a bad headlight switch and it is £300 for the part from the Citroën Dealer. Any ideas of what might be wrong and other less expensive ways of fixing this problem? Is there a relay attached to the headlight system that can be changed? Does the switch normally go bad and can it be fixed or is it better to get a used one instead of a new one?
View user's profile
Citroen C5 Headlight Problems
- x 9
The chain from the switch to the light is long and complicated and depends on the spec of the car. Basically a signal from the switch goes to the BSI either as discrete data or on a data bus depending, the BSI in turn drives relays on the Relay Unit under the bonnet, via a data bus.
You really need a man with a Lexia to read all the ECU's involved as the problem could be in any one of those three units.
cachaciero
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
