Xsara overheating
grigoris
Xsara overheating
Unread post by grigoris »
I've got a Xsara 1.6 Exclusive 97 with 60000km. The normal operating temp was about 90 deg C even in the warmest days (ambient temps as high as 45 deg C). Few days ago it appears to be running in higher engine temperatures. The temp indicator rest in the middle between 90 - 105 deg, moving upwards in heavy traffic jams or with the ac on. The temperature sensor that switches the cooling fans was replaced with no results. Both fans work ok in both speeds, new coolant was filled in during routine 60000km service, the cooling system was fully bleeded. Any suggestion will be welcomed!
Regards
Gregory
