The 4 speed heater blower on the ZX (1.9TD) has given up recently.
I have got it all to bits and have located the resistor unit, and the bottom end of the heater fan.
The resistor has got 5 wires going to it, 4 of which all show around 12 volts going to them when the switch is in the 1 / 2 / 3 / 4 positions, but when its reconnected there does not appear to be any current going down to the fan motor.
However connecting the 5th wire, which appears to be the feed to the motor direct to the positive side of the battery (with the ignition off) doesn't make the fan spin either.
2 questions then - is the resistor unit faulty? and how do I check the fan motor in situ (which wire connects to earth - which to live)?
ZX heater blower not working
- x 94
paul in normandy
- x 94
- x 94
paul in normandy
- x 94
paul in normandy
