2.0 litre Hdi turbo failure....
centurus2400
x 4
Unread post by centurus2400 »
Following on from my earlier post about loss of power, I had a chance to spend some time working on the car this weekend.
First off I checked the vacuum solenoid valve, which on the C5 is cunningly mounted neat the bulkhead in an almost inaccesible position :evil:
The original part seemed fine, but I fitted the replacement one anyway and took it for a quick drive - absolutely no difference in the symptoms.Checking the pipework with a vacuum pump proved that there were no leaks, and on releasing the vacuum you could hear the actuating arm/wastegate operating.
I next lashed up a pressure gauge, and had a go at measuring the boost pressure when the engine was revved. It immediately became apparent that there was a loud, and not very healthy noise coming from the general area of the turbocharger, and that the maximum boost was somewhat less than10psi - told you my gauge was a bit of a lash up....but the boost pressure should be around 1 bar.
The next job will be to get the car up on ramps and check the turbo to intercooler pipe running underneath the engine for leaks, but given the fact that just sometimes, at 3000+ rpm, the turbo will briefly come to life for a few seconds, it's starting to look very much as if the turbocharger itself is poorly.
All the more annoying given that the car has always had 6000 mile oil changes and has only covered 140,000 miles.
Has anyone ever changed a turbo unit on one of these engines... I know the one on the XUD could be a bit of a pig. Does the Hdi follow in this glorious tradition? Just for a laugh I cheked the dealer price for a new unit, and at over £1300 I think I'll investigate cheaper options!
wright
Unread post by wright »
does the car rev freely or does it need to build up?
02 C5 2.0 hdi 110
x 1488
When did you measure the boost? Full boost is only developed under hard load - eg hill climbing in 3rd foot down at over 3k rpm. 10 psi is not so shabby - 1 bar is only 14 psi, and I'd have thought the factory design boost was <1 bar. You really need to get it on a decent diagnostic computer so you can read some live data....
Citroenmad
x 110
Unread post by Citroenmad »
Have you had it on a Lexia to see if it brings up any clues?
Turbo failure is very rare on the 2.0HDi 8v, in fact ive not heard of one need replacing, not due to a lack of performance.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Ive got a Turbo Failiure on an 8v Xantia HDi 110bhp...
Im also getting no boost, the engine starts fine, and revs nice and freely, but when I hold an intercooler pipe and fev her, the engine sucks the intercooler pipe IN rather then the turbo expanding the pipe under pressure... So I too also have a failed turbo on a HDi Xantia...
So thats TWO Chris.. :wink: :lol:
Paul
A very sad...
1994 XM 2.1 d auto
x 5674
Somebody put the turbo in upside down Malcolm?
citroenxm
Fallen Hero
x 70
Whos Malcolm?? :wink: :lol:
Paul
A very sad...
1994 XM 2.1 d auto
x 5674
citroenxm wrote:Whos Malcolm?? :wink: :lol:
Paul
Your alter-ego?
Sorry Paul.
citroenxm
Fallen Hero
x 70
If I put a HDi 90bhp turbo into the 110bhp then yes it would be the wrong way round... as the 90 and 110bhp turbos are completely different and wrong way to each other...
Paul
A very sad...
1994 XM 2.1 d auto
cachaciero
x 9
Re: 2.0 litre Hdi turbo failure....
Unread post by cachaciero »
centurus2400 wrote:Following on from my earlier post about loss of power, I had a chance to spend some time working on the car this weekend.
I assume that that's 10 psi relative and not absolute I would have thought that's not bad at idle or a tad above.
Turbo's are relatively simple as pumps go. In terms of failure there is little scope for partial failures they are either good or totally stuffed, usually with clouds of smoke, once they stop spinning the oil seals stop working.
If it will occasional give good boost at 3K ish I wouldn't have thought that there was a lot wrong with it. My suspicions would be an air leak if not in the pipework then the intercoolers seem quite prone to developing leaks or the waste gate valve is stuck partially open.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
centurus2400
x 4
Thank you all for your thoughts on this problem, and it's reassuring to hear that the turbos on the 110 are generally considered reliable and unlikely to fail.
The intercooler definitely isn't leaking, so really I have to get under the car and check the pipework from the turbo to the intercooler next. It could be that the strange noise I'm hearing is caused by a leak in that vicinity.
I don't think the wastegate valve is stuck but again I'll double check it while I'm grovelling around down there.
I just want to make absolutely sure that there is no 'mechanical' problem that needs resolving before I go down the Lexia route. If I need to do this, then I reckon it would be cost effective to buy one of the Chinese copies, I don't have a very high opinion of the local main dealer!
Citroenmad
x 110
We got a phone call from a friend with a C5 2.0 HDI 90 today, saying their turbo had blown up.
I think im right in saying the 90 and 110 turbos are very different. This problem on this car seems to be due to neglected servicing.
03 Seat Arosa 1.0S
citroenxm
Fallen Hero
x 70
Yes chris they ARE different..
I have a GOOD 90bhp turbo sitting around... I know its good, came off an engine that I converted to 110bhp so its in good order...
Are you fixing it, or advising the owner?
Paul
A very sad...
1994 XM 2.1 d auto
Citroenmad
x 110
The owner is going to try and fix it himself. He is still looking for a replacement turbo though ...
... ill PM you. :)
03 Seat Arosa 1.0S
fynnbar
Unread post by fynnbar »
The turbos themselves aren't different, but the actuators are; and these can be swapped separately.
AFAIK, the turbos are only mounted the other way round on the Synergie/Evasion/806/Dispatch/Expert etc. variants, and they have a different exh. manifold too. It's due to packaging differences with the 'people carrier' layout.
The 206/406 etc. 110s have the turbo the same way round as the 90s
i.e. exhaust on the nearside, inlet on the offside.
2004 Dispatch 110 HDi
