zx heater plugs
froggy
(Donor 2026)
x 4
zx heater plugs
Unread post by froggy »
Hi, how do I fit heater plugs on my 1995 zx ?
Is it easy ?.
What tools do I need ?
cheers Froggy
x 1480
Is it a NA or Turbo? NA is easier. Access is the worst bit - although a Lucas pumped NA is not bad, compared to a Bosch pumped Turbo. You only need a deep offset 12mm cranked ring spanner. And 5 joints in each finger :lol: Details of the job on a Xantia TD here: http://www.frenchcarforum.co.uk/forum/v ... hp?t=20675
Go carefully if the plugs feel tight once they are 'cracked' - I ripped a lump off the head on my sister's ZX D :roll: fortunately there was enough left to grip the plug, and a repair was effected with chemical metal!
x 94
Unread post by citronut »
as Richards says a 12mm cranked spanner, also an 8mm spanner, and i also use a long 1/4 drive extention with an 8mm socket and a deep 3/8th drive 12mm socket on the two plugs at the gear box end,
regards malcolm
