I'm not sure if I may ask another question, but someone will tell me if I shouldn't have.Vehicle is Xantia 2.0 Hdi 90 V plate 99.
The engine does not overheat even towing our caravan, but we have had a temperature stop flash for at least the last three years, previous to that it was intermittent, the temp. gauge hasn't worked for donkeys years. Now that the xant is a spare car I can work on it without time pressure to get all the electickery niggles sorted. When the fault was intermittent it could be triggered by setting the heater vent to demist, count to seven and the stop would flash, move the slider to centre count to ten and it stopped flashing. Turning aircon on had the same effect. Most of the time the nearside fan was running on high speed the offside one didn't run at all. I got another from a local scrappie, fitted it and reassembled most of front.
When I started the engine both fans went to high speed and stayed there, when I stopped the engine both fans dropped to slow and were still running 3 Mins after removing the key! Disconnecting the battery allowed the relays to drop out and the fans stopped.
For the fans to stay on low speed with Ignition off would indicate an alternative power supply for the control unit to enable it to short pin 1 to earth. A short to earth on the wire between relay terminal and the control unit would mean that the fans would restart when the battery was reconnected.
As to why the fans run at high speed, the controller must believe the engine is overheating, i.e low resistance across the temperature sensor except that a year or so ago the engine management light came on, and a quick trip to our local fuel injection specialists revealed that most of the problems were unimportant. All faults were cleared and one stayed, the ecu believed engine temp was -50 degrees! this made me think the temp sensor or its wiring was open circuit, this would explain the lack of movement of the temp gauge.
Confused doesn't begin to explain it.
It will get another dose of looking at next Wednesday afternoon if the weather is reasonable, I anyone could suggest a few tests to make I would be very pleased, I have multi-meters and lots of electrical bits around and am a fairly competent rough engineer. I am toying with the idea of a lexia but haven't learnt enough about the limitations and strengths of them yet.
Cheers Derek
our car spent Friday afternoon and Monday morning in the electrics area of the Factory!!
