c4 1600 hdi
1939
c4 1600 hdi
Unread post by 1939 »
hi every one dose any one no were this is fitted Ignition Coil Control Circuit High Voltage
relay is fitted at all thanks to any one that can point me to the right place :oops:
P616VKX
Re: c4 1600 hdi
Unread post by P616VKX »
1939 wrote:hi every one dose any one no were this is fitted Ignition Coil Control Circuit High Voltage
If the vehicle is a 1.6 HDi, it wont have ignition coil componants as far as I'm aware...
Stuart.
B564PLC - Red/Grey Renault 11 GTL 'Premiere'
fynnbar
Unread post by fynnbar »
Correct. You've interpreted a fault code relating to a petrol engine. You need to relate the same code to a diesel. You have the 1.6 HDi DV6 engine.
Ah, just seen this is a double post ... same info in the other one !!
2004 Dispatch 110 HDi
P616VKX
fynnbar wrote:Correct. You've interpreted a fault code relating to a petrol engine. You need to relate the same code to a diesel. You have the 1.6 HDi DV6 engine.
Feel free to re-iterate... My knowledge of Diesels is limited AT BEST!
Stuart.
