Hi all,I have an 8 valve, 2 litre hdi ,y reg cit c5 that needs suspension attention.Does anyone know if I can use the rear rams from an hpi car (petrol) on mine - its got the middle sphere so its the hydractive + but the rams complete look in good nick so can i just swap them - my c5 is an lx with the hydractive non plussed without the middle height regulator sphere.
In short is there any difference between the actual sphere and piston set up in an hpi and an hdi early c5 ??
many thanks for any help
suspension swap
- x 9
As far as I can see at a practical level the struts are identical you will however need to use your original spheres as the spheres for H3+ will be different pressure.
Of course you could fit the H3 + system would need to add a couple of wires from the BHI to drive the EV though.
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
1984 Ford Scorpio
Renault 21
1220 GS Club
Rover P6 2000TC
