I have a Citroen Zx 1.4i with power steering about a month ago I had to have new inner track rod ends fitted. Shortly after a noticed a knocking noise in the steering column and a similar noise when driving over bumps in the road took the car back to the garage to be told there was no play in the steering.
On investigating myself I found that from within the engine compartment I can lift the left inner track rod ends up and down but trying to feel any play in the steering at the front wheels nothing. took the car back this time on second occassion to be told that this is normal for this up and down movement, however on questioning the mechanic and pointing out that other side has no movement he came out with a lame excuse.
Is the up and down movement on the left inner track rod end normal when pulling it up and down from within the engine compartment.
LEFT INNER TRACK ROD END HELP!!!!!!!
Dave Burns
CITMAN
wrinklet1
Is the steering rack similar to the one in the BX? If it is, remove the lower cowl on the steering column, and the steering rack goes through a tube with rubber bushes holding it in place. On the BX the lower bush could work loose and slide out out the 'tube', it may be that the ZX may have a similar steering set up.
All you have to do is, align up the bush and force it back in with a broad bladed screwdriver, then give the lower end of the 'tube' a knock with a hammer and it will flatten it up and the bush will stay put.
Give it a try....
Regards
Paul.
Give it a try....
Regards
Paul.
