307 rear abs sensor
wright
307 rear abs sensor
Unread post by wright »
I need to replace the rear abs sensor on my mothers 307 and i was looking for the part no, is there a site like the citroen service site where i might get the info i need, the local peugeot want €70 + vat, i've seen then on ebay for €25 + postage
MikeT
x 232
Unread post by MikeT »
wright
thank you, that will be very usefull
The Birdman
Unread post by The Birdman »
Try just cleaning it first
For what we are about to receive may we be truly thank full.
http://www.citroencodes.com" onclick="window.open(this.href);return false;
http://www.peugeotcodes.com" onclick="window.open(this.href);return false;
mickeybo
rear abs sensors
Unread post by mickeybo »
I would remove abs wheel speed sensor using a 5mm allen key remove any rust between back plate & sensor refit sensor make sure gap between
sensor & bearing does not exceed 1mm. You most likely have to fit a shim between sensor and back plate to get the required gap. Hth Regards mickeybo
