long story short. kerbed s2 activa sideways in snow at aroun 10 mph, temporary short bolt pulled thread out of hub.replaced hub car still pulls hard left at low speed. changed front wheel for back still same. any advice
cheers holmedog(mark)
activa pulling to the left
holmedog
- x 5
Gun Metal Grey Activa turbo,R.I.P. Gone to scrap yard in the sky and jims garage
Blue Activa from dr.madvibe
Silver Activa lost soul
addo
- Sara Watson's Stalker
- x 95
I'd say get the car on a hoist first, look for obvious damage.
If it's all normal enough then you'll need to check the chassis/subframe alignment and it may need some work on a rack. Not the old "chains on the floor" type but a proper repair fixture like a Celette or Globaljig - this should be achievable with minimal stripping of the car, so ought be cheap enough.
handyman
You may possibly find the trackrod end swivel is bent. They do do it, as the threaded rod has a kink in it causing it to deform when any sideway force is applied to the wheel/hub assembly.
Alternatively, get a long tape measure and measure wheel centres on the offside and nearside. They should be equal. If not something is out of alignment and you need to start looking deeper.
Bent lower wishbone or twisted lower hub assembly?
Handyman
Handyman
lefgrter
addo wrote:Not the old "chains on the floor"
I had a better experience some years ago. I had the same problem with my Alfa 33, and the mechanic chained the front right of the car to a concrete column, put reverse and started to pull the column. Magically he managed to fix the problem. (I assume he was (I was) lucky)
Xantia II 2.0T Activa
holmedog
- x 5
- x 8441
Most likely, the "P" bush has collapsed and is allow the wishbone end to move around all over the place...
The "P" bush is the back mount on the wishbone and is, in effect, a rubber donut. It's a known trouble point and if already a bit perished, a good knock could well have finished it off Mark.
The subframe is very strong in that area and I doubt it has suffered.
Remember the wishbones on the Activa are special as they have the Activa roll corrector link rods attached to them. However, that said, the wishbones are meaty old things and unlikely to have suffered.
My money is on the "P" bush...
holmedog
- x 5
handyman
No, car on axle stands, wheel off, spanner and air ratchet unbolts it, slip it off the pin on the wishbone and refit new unit. A little spit or washing up liquid helps ease the new one on, or KY jelly, if you are Citronut. As BOL states, assembly is the reverse of disassembly.
It is a relatively simple job, if you know the right end of a spanner.
If you do change the bush, get the tracking (wheel alignment) checked and adjusted if needs be.
Just thinking, have you checked the rim and tyre for any damage, like buckles or bulges in the tyre? These can cause the symptoms you describe.
Handyman
Handyman
holmedog
- x 5
Already looked at that handyman and changed front for back to make sure
but will definately check the bushes
many thanks holmedog(mark)
