Xantia battery drain - hydractive fault?
andyl
My 97 CT Turbo estate has suffered from battery drain when left unused for a period (2-3 weeks or so). I discovered a high drain to the alarm system (Fuse 17) so disconnected that some ago, and it seemed much better. However, the battery is still draining, after a longer period - I've found that fuse 8 (engine compartment) is showing 0.67amp with everything off. The handbook says this is for the Hydractive system. Any ideas what this might be? A stuck hydractive valve? Apart from this battery drain problem, the car is brilliant, but gets used very irregularly - university trips, holidays in the alps etc. We keep thinking about replacing it with something less thirsty, but if we can keep it going by throwing the odd £200 at it.....
DickieG
- Monaco's youngest playboy
- x 38
I had this same problem with my previous estate, it was due to the boot lock switch not closing due to wear in the lock pivot pin, a similar cause can be if the switch isn't correctly located. Either of these will cause the Hydractive suspension to be constantly turned on, hence battery drain and if its set, the alarm to be triggered.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1240
andyl
Thanks DickieG, that's the other fault with my car I didn't mention. The tailgate central locking hasn't worked for a year or so (I have to use the key) - could it be the same problem?DickieG wrote:I had this same problem with my previous estate, it was due to the boot lock switch not closing due to wear in the lock pivot pin, a similar cause can be if the switch isn't correctly located. Either of these will cause the Hydractive suspension to be constantly turned on, hence battery drain and if its set, the alarm to be triggered.
DickieG
- x 38
The central locking on my old car did still work but I imagine that had the problem been allowed to progress then that would have been a natural progression. As soon as the fault occurred repeatedly I investigated it at length so effectively caught it early.andyl wrote:Thanks DickieG, that's the other fault with my car I didn't mention. The tailgate central locking hasn't worked for a year or so (I have to use the key) - could it be the same problem?DickieG wrote:I had this same problem with my previous estate, it was due to the boot lock switch not closing due to wear in the lock pivot pin, a similar cause can be if the switch isn't correctly located. Either of these will cause the Hydractive suspension to be constantly turned on, hence battery drain and if its set, the alarm to be triggered.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
andyl
DickieG
- x 38
Attached to the mechanical catch/lock is a microswitch that is easily displaced or fails to operate if the lock catch pivot pin is worn, you'll need to remove the boot door trim to view it.andyl wrote:Thanks - I'm not sure what you mean by "the boot lock switch not closing"
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
andyl
