1999 HDi Exclusive
every now and then when the electrovalves open the front will sink about 2-3 inches and then pump back up. it doesnt matter if the engine is running or not as its done it coming out of a corner before and also when opening the door.
any ideas as with it doing it when driving i'd say its getting on the verge of dangerous.
Cheers guys
Random sinking of nose (xantia)
Chris570
- x 36
2006 C5 HDi 170
1998 Xantia Activa S1
1971 D Special
2018 Renault Zoe,
1971 D Special
2018 Renault Zoe,
A 1/3 of Team WFA 'Clarkson'CitroJim wrote: I'm a pink fairy
- x 8466
Chris, there are two possibilities here...
Either, your front hydractive sphere my be ruptured. It's a three layer one usually and these are either perfect or flat/ruptured with no leeway; they can go suddenly.
Or, you have a pressure regulation fault/lazy pump which is causing your front anti-sink valve to close whilst on the move and the sink you are experiencing is the result of the pressure rising to cancel the mainline/corner sphere differential and reopening of the valve.
The first can be tested by doing teh classic bounce test. Start up, allow full pressure to be developed, switch off, shut all doors and then bounce the front. After 30s when the hydractive system switches to hard, you should feel the front go very hard. Open a door to initiate soft mode again and you should feel the front go soft if the hydractive sphere is good.
The second can be provoked by aggressively bouncing the front with the engine idling. If it starts off soft and then suddenly goes high and hard, signifying the anti-sink valve has closed then that's the problem; low mainline pressure has caused the anti-sink valve to close. In doing this test it may be useful to have an assistant pump the brakes to simulate more load on the hydraulics. If the valve is closing in this fashion, giving the bouncing a rest will allow the pressure to recover and reopen the valve causing the front to both go soft again and drop.
Compare and contrast with your V6 if necessary...
