Having a starting problem with a V6XM auto, occasionally it is like trying to start the car in "drive", even if the 'box is in "park", sometimes it helps to rock the gearstick, not always!, I have checked all connections to battery, has had a new ignition module, coil,in fact everything ignition wise is new, I think it could be the inhibitor switch on the autobox, as this 'box was replaced last year with a used one- does anyone have any ideas if it could be the switch?, if it is, where on the 'box is it located? and what is involved in replacment ?
Do Andyspares carry this as a item?
XM V6 Starting Problem
lez
