Xsara Cruise Control Installation Problem!
BCD94
Unread post by BCD94 »
Hi to all, i have Xsara Hdi 2.0 110hp from 2002, and i installed cruise control on it! But i need help to activate it, because in Bsi i can see CC activation but on ECU it can´t be done! Anyone know what´s happening?
Thank you
wright
Unread post by wright »
it needs to be activated on injection ecu,
BCD94
wright wrote:it needs to be activated on injection ecu,
Hum, i thought that, but when i enter to configure ecu it has no option beside absent on cruise control! Can you help me? Please
x 1061
Unread post by wheeler »
The setting in the injection ECU is listed as RVV (a french abreviation for cruise control). Set it to present, after you have changed the setting disconect lexia & turn off the ignition for 3 minutes to let the setting change take effect.
BCD94
wheeler wrote:The setting in the injection ECU is listed as RVV (a french abreviation for cruise control). Set it to present, after you have changed the setting disconect lexia & turn off the ignition for 3 minutes to let the setting change take effect.
Yes i can see that function, but when try to change to other one it only do a window with absent! Is there anything wrong?
Another question is that in BSI it has 2 cruise control:
Cruise control activation
Cruise Control Multiplexed
It´s Multiplexed by COM2000, but i don´t know if he is refering it?
Other thing i only install Cruise Control Stalk, and it has Limit Function is there any problem with it? Com2000 hasn´t to be changed?
Thank you
wright
did you fit the extra brake switch, some xsara don't have the spot to put it, and in such case i would expect that it is probably an unavailable option
BCD94
wright wrote:did you fit the extra brake switch, some xsara don't have the spot to put it, and in such case i would expect that it is probably an unavailable option
:p sorry extrabrake i haven´t install it! i will see later if it has, but i think it has only one on it! If it misses ECU can´t recode to RVV? RPO 10348!
BCD94
Hi in citroen sevice i can´t see another brake switch, here is how it s mine!
Uploaded with ImageShack.us
x 1061
BCD94 wrote: Other thing i only install Cruise Control Stalk, and it has Limit Function is there any problem with it? Com2000 hasn´t to be changed?
The xsara was never available with speed limiter so it sounds like the stalk you have may be from a mk2 C5 ??
BCD94
Yes i bought a comm2004 and stalk from C2 car! But i thing there isn´t the problem? Beuase i tested on com2000 and it does all the buttoms except Limit function!
x 1061
Just wondering why you needed the complete com2004 ? an original CC stalk can be fitted into the existing com2000 much easier that replacing the whole lot.
BCD94
wheeler wrote:Just wondering why you needed the complete com2004 ? an original CC stalk can be fitted into the existing com2000 much easier that replacing the whole lot.
Hi i haven´t installed Com2004! I bought it with stalk! It´s fitted on original COM2000! Do you know how to activate it please?
BCD94
Anyone can help me please?
