307 heater controls
john alexander
307 heater controls
Unread post by john alexander »
Hi is it possible for the independant controls for the temperature to be linked as I am fed up having to set 2 controls, 2 zone heating , only handy if your giving an eskimo a lift P.S it's a 05 307 sw 1.6 hdi . as always thanks in advance .
Citroenmad
x 110
Unread post by Citroenmad »
I like the idea of the dual zone climate, as i often want to be a different temperature to my passenger!
However, im not sure if or when the controls changed on the 307. I know on the S1 C5s you could not set them by using one side, you had to adjust both. But with the C5II you can set it so everything adjusts together.
Might be in your menu if you have such a thing?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
