Does anyone know the Head gasket torque and seqence?????
I am going to be using th thicker head gasket
think it might be 20nm then 120 then 120 degrees
206 1.4 02 reg Head gasket torque and seqence?????
rich201283
fynnbar
- x 94
the undooing sequence is ever decreasing circle from one end/either
re/fitting/torque
ever increasing circle from the two centre bolts,
i think the hayneeass BOL says 240 degrees,
which i think is best done in two stage's as you state 120 then 120,
also check the linner protrution as they need to sit proud of the block by so mant though,
regards malcolm
re/fitting/torque
regards malcolm
Oldpug
- x 94
