I am doing the head gasket and it is getting a pressure teast and skim.
There are 3 different head gaskets listed, each thicker than the other. Do i use 1 of these or put the standard on?
Pug 206 1.4 Head gasket thickness??????????
MikeT
- x 232
spider
- x 77
Although it might vary, I've always just put the thickest one on (certainly on diesels) as if you are skimming are you are (regardless of engine type) increasing the compression so a thicker gasket makes sense.
Andy.
Oldpug
- x 93
