saggy back end on zx
xantia sx auto
Unread post by xantia sx auto »
I got another zx today and notice the back end on the new one is higher than my old one, unfortunately i can't drive the new one as it's a manual and i only got it to swap some bits then sell on, is there something I can swap over to make mine as high as it should be or is it going to take too much work?
thanks
handyman
Unread post by handyman »
Rear height on the ZX requires stripping out the torsion bars on the rear suspension and resetting them on a different spline or two. Not a job for the faint-hearted! :shock:
Or you could take off the whole rear axle and swap them over. :roll:
H
xantia sx auto
so if i remove the entire rear axel do I need to worry about unloading the taution bars or is it just a case of unbolting the whole rear axel and then bolting it on mine?? is it a big job?
are both sides independent or does it all come out in one lump??
thanks
handyman
I was only kidding about taking off the rear axle. :shock:
You would need to jack up the car on stable supports, remove exhaust, disconnect brake lines and cables, unbolt front and rear sub-frame mounts, etc. You may then find that you need to replace all for sub-frame mounts, do any localized welding that may appear, ............ :cry:
Either way you are in for a job, along with the lose of skin on your knuckles.
If you want the back-end height adjusted, PM me.
H
spider
x 77
Unread post by spider »
Taking an axle complete is a lot easier than trying to take it apart to repair it, although in theory its only a few bolts to swap them, its has been said its all the other associated things you see not to mention brakes / handbrake cables etc...
Andy.
Chlorate
Unread post by Chlorate »
What model ZX is it?
I know Volcanes have a slightly lower back end than the garden variety ZX (or rather it should have).
Perhaps at some stage someone swapped a Volcane (or similar) back axle assembly on there?
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
