Hi Guys
Today I bought another zx it's a k reg td manual and the speedo, rev counter and temp guage are not working, I see a few people have had speedo problems but is there something common that makes them all go? i'm hoping it's just a loiose connection somewhere of a fuse, or is it something different? my other zx speedo needle wobbles at about 40 but still works, are the rev counters electronic??
I hope someone can help
Rich
zx speedo rev counter etc
spider
- x 77
K plate should be cable drive later might be electronic.
Examine fuses.
Next examine rear washer relay (yes really) in the hatchback trim panel for signs of water. If this gets corroded this causes one fuse to blow which does effect the panel.
Failing that it might be something relatively simple like a broken earth lead around the panel wiring.
Examine fuses.
Andy.
xantia sx auto
- x 1240
spider
- x 77
Said link does cover the multipin plugPeter.N. wrote:..or the two pin plug that connects it to the loom, not very easy to get at but on the gearbox end of the cylinder head, just above the gearbox.
Mine was actually floating in the breeze, I've poked it behind the starter motor for now and neatly cable tied the excess up as there was about half a mile of un-needed cable, I thought about cutting it down but given how sensitive they are I though against it.
Andy.
- x 1240
xantia sx auto
I have looked all around the end of the head and can't see anything, I found the plug by the oil filler, and unplugged it, that looks fine, the wire seems to go from there down into the area of the speedo cable but I can't see where even with an extending mirror! has anybody got a piccy of where the sensor plug is ??
thanks guys
car is now for sale, it's a td with only 124k on it but I can only drive autos and I was going to try and swap all the bits onto my 1.9 auto but it's too hard so I just swapped the wheels and selling the rest if anyone is interested, its got mot till june, i'd like to fix the revs really as it's a lovely car and no rev counter might put buyers off
it's on ebay
CITROEN ZX AURA TURBO DIESEL WHITE MOT & TAX 5 SPEED
thanks guys
thanks guys
it's on ebay
thanks guys
spider
- x 77
