C5 estate rear glass opening switch
johntom
Unread post by johntom »
Hi
does anyone know of a source for a new micro switch for the rear opening glass (the little switch under the rear wiper) on a 2004 C5 estate ?
john alexander
Unread post by john alexander »
probably not the switch, check the other posts on here , it's likely the wiring
cachaciero
x 9
Unread post by cachaciero »
It's just as likely to be the switch as the wiring, the switch can be purchased from CItroen, they arn't that expensive as I remember.
cachaciero
2006 Toyota Prius T Spirit
2001 2.2 C5 Exclusive SE
1996 XM 2.1 TD Auto VSX
1987 CX 2.5 Gti Turbo II dead
1984 Ford Scorpio
1981 CX 2.4 Pallas Auto
Renault 21
1220 GS Club
Rover P6 2000TC
john alexander
Get back to us with the answer
johntom
Hi
it's definitely the switch. I rang the local dealer a few weeks ago, i'm sure they wanted around £30 for the tiny microswitch so i didn't bother ! Just wondered if someone had found an alternative source for the same thing.
