Xantia 1.8 16v
Martin928
Xantia 1.8 16v
Haven't taken delivery of this car yet, but does anyone know if the wiring is in place for electric leather interior, please?
citroenxm
- Fallen Hero
- x 70
Depending which model spec. and what year.
If its an early on, IE: 1996 or so, and an LX then likely not.
Theres a chance though if its a later car - 1997 possibly and an SX spec...
But personally, Id assume NO there is not. However, its really NOT that hard to wire in a power feed for them! I did this in a S2 LX Xantia, with No rear electric windows or harness's for seats! I picked the power from the Spare Electric Sunroof plug that was hidden under the carpet! I had recovered the floor harness from the car that had the leather in it in the forst place though.
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Martin928
411514
- (Donor 2017)
- x 39
No experience on the xantia,but i did this on the c5 and found that the wiring was there ready to plug in but was seemingly not connected/configured with the bsi. If this is the case for you its an easy fix to run a power cable straight from the battery to the seat fuse panel (on the c5 behind the glovebox), good luck with the fit.
