Re-fitting badges.
C.J.
Re-fitting badges.
Unread post by C.J. »
Any of you guys got a quick fix solution for re-aqpplying these plastic badges, namely the boot fitted Citroen and Xantia ones?
Took the old ones off, but it destroys the sticky tape that's cut to the same shape as the badges.
Tried superglue but they've fallen off again, and they looked messy anyway. :x
Colin
My cars:
1988 AX GT and still running sweet. Genuine 41 k only!!
2005 Skoda Fabia vRS 83k...and truly awesome.
Vauxhall Combo crew cab SE
Citroen Saxo 1.4 Furio.
Their cars:
Hyundai Getz.
Hyundai i20
Eriba Puck caravan now too!!
JamesQB
x 5
Unread post by JamesQB »
I bought some badge adhesive strip from eBay to do mine. I went for the expensive type that's apparently used by a few manufacturers. Bit fiddly cutting lots of little pieces to go around curves and things, but did it months ago and much rain, snow and ice later, they're still stuck firmly in place and looking good.
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
andmcit
x 30
Unread post by andmcit »
Halfords and the like all sell double sided adhesive pads for holding
number plates. They're thin (1-2mm) and green/black. If you use these
and cut them into narrower strips so the're hidden within the badge area
you'll find they're damned good at holding anything.
Andrew
exect
Unread post by exect »
You beat me to it, numberplate fixings
Exect
C.J.
Thanks, but this is the very problem I'm trying to avoid. The intricate cutting around the edges of the letters and holes.
Look like a mission impossible to me. :shock:
Can't even find exact new repalcements on flea bay either.
Colin
My cars:
Their cars:
Hyundai Getz.
Hyundai i20
HDI
x 7
Unread post by HDI »
Silicone gasket sealer.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Most badges for the Xantia are still available OTC. Series 2, at least.
