Having searched the forum from page 1 - 88 I could not find a solution to my problem which is the electric windows on my car.
Both the passenger & drivers windows do not work,(which obviously means there is no power going to the switches unless the bulbs have gone which is doubtful)
When I put side lights on the switches normally light up, this now does not happen. I have checked the fuse F29- 30 and replaced it and still now function of the windows. I have tried to look at the rear of the Facia Fusebox but it only releases a fraction after releasing the locking plastic catch so I cannot look to the rear of the fusebox to see if the plug has released itself.
If anyone can make any sense of my wording. How can I check the rear of this box without having to strip all the facia. Kids are getting fed up with their daddy saying open the back windows [B)]
Electric Front Windows
alan s
- RIP 2010
- x 6
mbunting
Erm, I dunno if my 94 is suspect, but all my windows, and the switch-lights are on as long as the aux power is available, regardless of side/headlight state. As Alan says, sounds like an electrical gremlin here, and bearing in mind our different aparent 'configurations', either you or I may have a dodgy relay !
- x 1044
BarmyDragon
Checked the fuses and both are active with ignition at accessory. Will have to trace along the wires when I get a moment poss break [:(]
<b>mbunting</b> you say a a poss dodgy relay. Either the Dealers are trying to rip me off and get me to fork out £45 an hour to spend time on doing a wire check but they say there is NO relay for the electric windows ?? [:(!]
Dave Burns
- x 1044
according to the diagram there is a relay,i dont know wich one it is exactly but its where i would start checking next,pin 2 of the relay should be earth,pin 1 should be the accesory feed from fuse 30,pin 3 should be a permanant live (from fuse 29),pin 5 wire should go live with the ignition on (output to the window switches).the relay should be a green plug.
Guru Meditation
stuartb
cheesesliceking
OOh OOh i might be able to help!! Jesus i hvent been able to give advice before!!
I had the Exact same problem on my previous AX GT, turns out that the rubber tubing from the door to the car body contains the electric windows/speakers/central locking wires. The wire on mine had snapped and thus the window didnt work.
Wey Hey, !! hope that helped[:D][:D]
