Fuse for ECU?
XantiaMan
- x 18
Fuse for ECU?
Is there a fuse that cuts the power to the ECU? My Activa ran very low on fuel earlier, only on the drive, so low that the pressure dropped and it threw a code! Rather than disconnect the battery and then reset the radio code and time etc, be easier to pull a fuse out for 10 minutes and refit.
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
2017 Fiesta ST
- x 1923
The warning lamp should reset after five (I think) restarts. It does on my C5 and Xsara if I misjudge the fuel levels.
DickieG
- Monaco's youngest playboy
- x 38
XantiaMan
- x 18
Thanks Richard, i did think of that but thought it might be a wise thing to shut the power off first, if you dont see a problem done this way then that is what i shall do!DickieG wrote:Unplugging the ECU is easy and will achieve the same as removing a fuse.
2017 Fiesta ST
2017 Fiesta ST
XantiaMan
- x 18
Works fine and a damn site easier than disconnecting the battery!
2017 Fiesta ST
2017 Fiesta ST
DickieG
- x 38
