16v Hdi diesel head gasket
tobytronicstereophonic
Unread post by tobytronicstereophonic »
Hello, I need to remove the cylinder head on a 16 valve Grand Picasso Diesel engine. The engine code is: RHW. Does anyone know of the head bolt torque/angle figures. Also, is there an online engine service manual for it anywhere?
Has anyone out there done this job before?
Is there any problem with replacing the combined inlet manifold/cam bearing assembly?
Thanks, Ian.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Hi..
Theres a much higher chance you having a problem getting the injectors out, to remove the inlet manifold, to get at the head bolts..
Injectors useualy refuse to move.. But WELL DONE if you have removed them!!
The 2.oi 16v HDi hasn't filtered down to many of us yet... the only 16v engine that has is the 2.2 in the First Gen C5.. which can cause good headaches...
Our best later HDi man is Chris - citroenmad
Paul
A very sad...
1994 XM 2.1 d auto
Toby_HDi
x 3
Unread post by Toby_HDi »
I'm not aware of any online manuals for the 307 but Haynes has released a 307 edition which may be of some use, providing it doesn't tell you to take it to a dealer for everything.
Torques are:
Stage 1: 20Nm
Stage 2: 60Nm
Stage 3: Slacken 360°
Stage 4: 60Nm
Stage 5: 220° ±5
The maximum bolt length is 134.5mm
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
citroenxm
Fallen Hero
x 70
307 TOby?
I thought he said C4 Grand Picasso.... Did the 307 get the 2.oi 16v lump?
Paul
A very sad...
1994 XM 2.1 d auto
Toby_HDi
x 3
My mind is wondering tonight. For some reason 307 was in my head.
Apologies.
They are the correct torques for the RHW engine though
Toby
Previous:
Citroenmad
x 110
Unread post by Citroenmad »
Is this a 1.6 or 2.0 HDi Picasso?
This is the first report ive heard of with a later 16v HDi having a head gasket problem, very unusual, and there are many higher mileage examples of these around.
What mileage has this one done?
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
x 1486
Haynes for the C5 covers this engine (well sort of - there were quite a few bits missing when we did the clutch on my mate's C5 2.0HDi 16V a couple of weeks ago). Not sure how much detail it goes into on the engine, but there's deffo a section on it!
