Maybe a daft central locking question???
I own a 51 plate dispatch but dont have a central locking key fob just the standard key.Right the possible daft question : is there any power to the main front door locks (rear doors have seperate deadlocks allround) or does the central locking work in some other weird & wonderful way.I have had the door skins of to replace the lock barrels thanks to the old spinning lock problem and no electrical connection in sight,I have been told by a citroen dealer that this model did have central locking having checked against the chassis number but was a bit vague about needing power & nobody else around to ask,so over to you ladies & gentlemen.
here if it works is the complete list of every thing on your vheicle from your chassis No. on service citroen,
Vehicle family DISPATCH I & II
AS RPO No 09082 U9 1 0364
Warranty Start Date 24/12/2001
Engine serial number 10 DYLB 4002494
Gearbox serial number 20 LE93 0449944
OPB 4005
General information
PRODUCT TYPE UTILITY VEHICLE
COMMERCIAL MARQUE/COMPONENT TYPE CITROEN
VEHICLE FAMILY DISPATCH
SILHOUETTE TYPE 900 VAN SHORT
TRIM LEVEL LEVEL 1
ENGINE DW10BTED TURBO DIESEL
TRANSMISSION BVM5
INTERIOR TRIM TYPE DN PABLO CLOTH
UPHOLSTERY COLOUR FT
GEARBOX (CHARACTERISTICS) BVM ML5T
ENGINE (TYPE) EW/DW
OTHER BADGE 2 0 HDI
BADGE WITHOUT BADGE
Vehicle characteristics
TRIM LEVEL LEVEL 1
STEERING POWER STEERING
SPEEDOMETER DRIVE TACHO TORQUE 25X20
Fuel supply-Engine
FUEL FILLER CAP FUEL CAP WITH LOCK
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL DIESEL FUEL
EMISSIONS STANDARD (ENGINE) EEC 95 DEPOLL (ENGINE)
PRE-FILTER ASSEMBLY WITHOUT PRE-FILTER
ENGINE (TYPE) EW/DW
CATALYTIC CONVERTER 3 PARTS CATALYST
OIL COOLER MNTG WATER/OIL EXCHANGER ON ENGINE
VEHICLE EMISSIONS STANDARD (TYPE APPROVAL) EEC W3 DEPOLL (HOMOLOGATION)
CRANKCASE GAS CIRCUIT HEATING W/O HEATER CASING GAS CIRCUIT
VEHICLE TECHNICAL DEPOLLUTION W3 VEHICLE TECHNICAL DEPOLLUTION
FAN 1 FAN 2 SPEEDS 420W
FUEL VAPOUR RETRIEVAL WITHOUT PETROL VAPOUR RECUPERATION
INJECTION ASSOCIATED VARIANT MOUNTING BOSCH
Gearbox-Driveshafts
TRANSMISSION BVM5
FINAL DRIVE RATIO REAR AXLE HYPOID GEARSET 14 X 71
WHEEL STYLE 1/2 STYLE WHEEL
CLUTCH HYDRAULIC CLUTCH
DIFFERENTIAL (GEARBOX) STD GEARBOX DIFF
TYRE (SIZE, TYPE) 205X65X15 T TYRES
WHEELS FITTED 6,5" RIM ROAD WHEELS
WHEEL (TYPE) STEEL WHEELS
GEARBOX TYPE GEARBOX ML
Suspension-Steering-Brakes
ABS W/O ABS BRAKES
STEERING COLUMN ADJUSTABLE STEERING COLUMN
FRONT ANTI-ROLL BAR WITH FRONT ANTI ROLL BAR
BRAKE TYPE VENTILATED FRONT DISCS/REAR DRUMS
SUSPENSION NORMAL SUSPENSION
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORN STANDARD
AERIAL MANUAL AERIAL
CHASSIS SHORT CHASSIS
PAYLOAD LOAD CAPACITY 900 KG
SIDE MOULDINGS (DIMENSION) WITHOUT LATERAL PROTECTORS
WHEEL EMBELLISHER (STYLE) WHEEL BADGE CAP
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
THIRD BRAKE LAMP WITH EYE LEVEL REAR LIGHTS
HEADLAMP WIPER W/O HEADLAMP WIPER
SIDE LOAD DOOR LH/RH SIDE SLIDING METAL DOORS
BUMPER DYED FRONT/REAR BUMPER SINCE MOD2000
FRONT FOGLAMP NO FRONT FOG LIGHTS
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE) NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE) PASSENGER’S DOOR MIRROR MANUAL CONTROL
SPARE WHEEL MOUNTING STANDARD SPARE-WHEEL CARRIER
SUN ROOF FIXED ROOF
REAR WINDOW (TYPE) WITHOUT REAR WINDOW
GLASS (APPEARANCE) TINTED
REAR QUARTER WINDOW (TYPE) WITHOUT REAR QUARTER GLASS
WINDOW (TYPE) NON ATHERMAL WINDSCREEN
SIDE WINDOW (COMM. VEH. ONLY) WITHOUT SIDE WINDOW
Interior fittings
ANTI-THEFT ALARM WITHOUT THEFT PROTECTION ALARM
CIGAR LIGHTER FRONT CIGAR-LIGHTER
FRONT HEAD RESTRAINT FRONT HEADREST ADJUSTABLE
REAR SEAT WITHOUT REAR SEAT POSITION
SUPPLEMENTARY SEAT WITHOUT SUPPLEMENTARY SEAT POSITN
CABIN SEAT 2 PLACES PASSENGER BENCH
RADIO TELEPHONE WITHOUT TELEPHONE PRE-EQUIPMENT
REAR SEATBELT WITHOUT REAR SAFETY BELT
FRONT SEATBELT PYROTECHNIC SEAT BELT WITHOUT ALARM + LAP STRAP
CLIMATE (AMBIENT TEMP) TEMPERATE COUNTRIES
SPEED GRADUATIONS GRADUATION MPH
TACHOMETER WITHOUT REV COUNTER
RADIO EQUIPMENT FEED AERIAL RECEIVER FRONT SPEAKER
DRIVING POSITION RIGHT HAND DRIVE
REMOTE CONTROL WITHOUT REMOTE CONTROL
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
BLOWER FAN UNIT 1 FAN HEATING UNIT
WORK TABLE WITHOUT WORK TABLE
INSTRUMENT PANEL (CHARACTERISTICS) 4 DIALS
LOUDSPEAKER MOUNTING 2 FRONT LOUDSPEAKERS
RADIO CONTROLS WITHOUT REMOTE RADIO CONTROL
DRIVER SEAT CONTROL DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL W/O PASS FRONT SEAT CNTRL
DRIVER SEAT ADJUSTMENT RECLINING DRIVER’S SEAT BACK
FRONT PASSENGER SEAT ADJUSTMENT FIXED PASSENGER SEAT BACK
FRONT SEAT ARMREST ASSEMBLY WITHOUT FRONT ELBOW REST
EXTERIOR TEMP. INDICATOR WITHOUT EXT TEMP INDICATOR
STOWAGE BIN WITH SETTING BOX
DRIVER’S WINDOW LIFT MANUAL CONTROL DRIVERS FRONT WINDOW LIFTER
PASSENGER’S WINDOW LIFT MANUAL CONTROL PASSENG FRONT WINDOW LIFTER
SUPPLEMENTARY SEAT SEATBELT W/O SUPPLY SEAT SAFETY BELT
OIL GAUGE OIL LEVEL WARNING INDICATOR
HEATING ELEMENT NON HEATED SEAT
PASSENGER AIRBAG NO PASSENGER AIRBAG
REAR MOVING PANEL 2 REAR HINGED METAL DOORS
HEADLAMP HEIGHT ADJUSTER REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD WIDE LADDER
RADIO RECEIVER RB1 RDS CASSETTE AUDIO SYSTEM
REFRIGERATION WITHOUT AIR CONDITIONING
CRUISE CONTROL WITHOUT SPEED CONTROL
DRIVER’S SEAT HEIGHT CONTROL PARALLEL DRV HEIGHT ADJ
AIR CON./TEMPERATURE REGULATION WITHOUT REGULATION AIRCON/TEMP
DRIVER AIRBAG NO DRIVERS AIR BAG
CARPET RUBBER CARPET
SWITCH ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR WATER TEMP INDIC +RED TELLTALE
LOCKING CONTROL STANDARD LOCKING
STEERING WHEEL RUBBER STEERING WHEEL
Electrical
ALTERNATOR ALTERNATOR 90 AMP
HORNS HORN STANDARD
BATTERY BATTERY L1 300
STARTER MOTOR STARTER MOTOR CL 5
SPECIAL LIGHTING WITHOUT PARTICULAR LIGHT
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS NORMAL ATMOSPHERE
VIN PLATE OUTSIDE EUROPEAN UNION CONSTRUCTOR’S PLATE
DOOR SEAL SEAL DIRT EXCLUDER
SURFACE CONDITIONS GOOD TERRAIN
SPEED MONITORING WITHOUT SPEED CHECK
regards malcolm
OPB 4005
General information
TRIM LEVEL LEVEL 1
TRANSMISSION BVM5
ENGINE (TYPE) EW/DW
OTHER BADGE 2 0 HDI
BADGE WITHOUT BADGE
TRIM LEVEL LEVEL 1
Fuel supply-Engine
FUEL DIESEL FUEL
ENGINE (TYPE) EW/DW
Gearbox-Driveshafts
TRANSMISSION BVM5
ABS W/O ABS BRAKES
Body fittings
HORNS HORN STANDARD
SUN ROOF FIXED ROOF
Interior fittings
Electrical
HORNS HORN STANDARD
Miscellaneous
regards malcolm
- falling-out-with-my-car
- My Cars: Citroen C5 Aircross 8 speed Automatic, Flair Model with far to many toys and nice comfy armchair like leather seats. ha ha Ive just had a conversation with the car. setting everything up verbally
- x 24
I had this problem try pushing the key right into the lock and it should lock.
