Pressure in Coolant and coolant loss
the moog
Unread post by the moog »
I am still trying to chase all my gremlins in my car (1997 1.9TD with 130K)
I keep losing loads of coolant. It seems to go through the whole lot in about 2 weeks. I cant see where it is going. I have noticed a few drips underneath but with the wet weather it is hard to find.
I am also find that the cooling system is massively pressured. Earlier I ran the car for 5 minutes then let it stand for 30 minutes. When I went back the top hose was still rock solid and when I opened the cap carefully it spat coolant everywhere!
I have fitted a new thermostat and rad cap in case either of those was leaking.
Is it the HG? Are they hard to do?
1997 Xantia 19.td Estate in Blue
HDI
x 7
Unread post by HDI »
Head gasket !! Not hard to do, unless you find other issues when it's apart, like corroded head surface etc.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
the moog
Excellent .. just the thing when I am moving house and losing car working space !
Any idea of time to do it? Fairly competent with the spanners but no expert
Or a rough indication of garage cost?
HDI
x 7
Have you noticed any difference in coolant temperature or more than normal condensation from the exhaust ?
Head gasket would probably take a weekend without proper facilities, garage would probably want at least 6-8 hours + parts. So labour would be at least £250.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
the moog
Been running it on SVO and the oil smell has been bigger than normal and a lot more white smoke! I assumed it was cause it had got cold.
Temp hasnt been rock steady like it has been.
I think it is going to be a step to far for me at the moment.
Chlorate
Unread post by Chlorate »
Textbook XUD head gasket right there.
Sounds like it's not too bad if it's losing all of its coolant over 2 weeks, hehe at the end of my old head's life it would lose all of it in about 20 minutes :lol:
It's always advisable to have the head sent off to be skimmed before putting it back on, especially if it's been overheating. A lot of places can pressure test the head for cracking too, it's not always obvious just by looking at it.
Although if it hasn't overheated, it may be ok to just bung it back on.
Good luck, it's not toooooo hard but it is rather labour intensive and some bits are very fiddly.
Good opportunity to do some of those "may as well whilst I'm here" jobs too, like a new timing belt and water pump etc.
-Alex
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
Xantidote
x 4
Unread post by Xantidote »
When I did the head gasket on my TD, I replaced the head bolts - IIRC, it was Haynes that said to replace them. Didn't begrudge their replacement, for peace of mind, but what's the general forum view on their replacement? Obviously there's a cost issue.
Fitted a genuine Ciroen head gasket
Martin
1995 Xantia TDLX (deceased :( )
x 1507
They're stretch bolts - there used to be a figure for the allowable amount of stretch, but given the abuse they get on tightening up would you want to have to do it all again for the sake of a set of bolts?
Chlorate
My ZX Haynes gives a value for the maximum stretch on the head bolts (haven't got it to hand, it's in the car). If I recall there are two different kinds of bolts for whatever reason.
I'd say it'd be safer to just put some new ones in, but then again if they're within the allowed limit I can't see why you can't do it
RE: Price - I think mine cost an extra £15 on top of my gasket set, granted it was a pattern gasket...hasn't failed yet :lol:
-Alex
previously:
x 1240
Unread post by Peter.N. »
If you dont have time to do it now try running it with the pressure cap not screwed right down, that will allow the pressure to escape without blowing the water out, unless it is very bad. I have been running an XM like that for the last 5,000 miles or so :D
Chlorate
I removed my fuel filter housing bleed nipple when I got stuck at Clacket Lane services :lol: my head was so bad that cranking the bloody thing pressurised the coolant system too much.
Ended up needing a new head...
Ahem.
Great engines these :D They're just a touch fussy when it comes to antifreeze.
previously:
fred1
Unread post by fred1 »
fred1
Might only be a short term temporary solution but have seen claims that
"K Seal" can fix head gasket failures.
Cost about £10-12 and might just buy you time till you can fix the head gasket properly. I believe its avalable over the web and at GFS etc.
Could be worth a try.
regards
John
