problem with lights
doobryfirkin
problem with lights
Unread post by doobryfirkin »
hi
im new to this forum so i do not know if this topic has been put up before, i own a 1997 xantia 2.0L auto estate my MOT is due and i had 3 bulbs out one on the tailgate drivers side, the passenger side brake light and the passenger wing indicater i replaced all 3 now when i indicate to turn left all the lights flash on the rear of the car and the small bulbs on the headlights when i put my lights on all the indicater lights on the left stay on if i put my hazzards on thay do not flash i have checked the bulbs replaced them made sure thay are in the right way replaced the relays checked the 2 earth points at the rear and checked all fuses can anyone help please :( :( :( :cry: :cry: :cry:
Tony
handyman
Unread post by handyman »
Hullo Tony, is it possible for you to edit your post, so it is easy to read, rather than being a huge stream of consciousness? I lost the will to live, halfway through reading it. :shock:
Or is this just spam? :roll:
Handyman
doobryfirkin
i did not think 4 lines was excessive but if did not tell you what the problem was and what i have tried how are you supposed to know
Tony
handyman
Hullo Tony, I've reread this a few times now and there still seems to be a few confusing elements in your script.
I do not wish to appear rude, but do you know how to use a little punctuation? It would make it easier for some of us to comprehend what you are asking and thereby offer a solution to your problem or steer you in the right direction.
From what I can gather, it looks like you have a misconnection or a short in the wiring. Any of the magic smoke eminating from the indicator stalk or around the steering wheel boss? Looks like you need to test for insulation and continuity. Be careful, wiring harnesses burn very easily. :shock:
Handyman
x 1480
Brake light bulb is in the wrong way round or is the wrong type.
Xaccers
x 186
Re: problem with lights
Unread post by Xaccers »
Firstly :welc:
I've hopefully clarified your first post:
doobryfirkin wrote: I'm new to this forum so I do not know if this topic has been put up before.
I own a 1997 Xantia 2.0L auto estate and my MOT is due.
I had 3 bulbs out, one on the tailgate drivers side, the passenger side brake light and the passenger wing indicater.
I replaced all 3 and now when I indicate to turn left, all the lights flash on the rear of the car as well as the small bulbs on the headlights*.
When I put my lights on, all the indicater lights on the left stay on, bit if I put my hazzards on they do not flash.
I have checked the bulbs and replaced them, made sure thay are in the right way, replaced the relays, checked the 2 earth points at the rear and checked all fuses.
Can anyone help please?
*Doobry, can you confirm that I've got that correct; when you indicate left all the lights at the rear and the small lights at the front flash?
DIY sphere tool
VertVega
x 13
Unread post by VertVega »
Thanks Xac :wink:.
I have read the message from the beginning to the end, from your "clarified version" :).
It makes such a big difference.
Could it be because of:
1. Wrong bulb type, as RichardW suggested,
2. Indicator stalk.
x 8292
The estate is well-know to have an issue with the tailgate wiring. The wires passing through the rubber concertinas up by the hinges are a bit on the short side and over time the wires can stretch, break and crack their insulation, leading to short circuits and the "funnies you describe.
My first test would be to disconnect all the rear lights at the sockets on the bulb carriers to see if the problem continues. If it then clears, the faults is in the bulb carriers. If it is the same, an investigation of the tailgate wiring is called for. Sadly, there's no easy way of disconnecting it all.
If it will help, I can offer you comprehensive wiring and harness diagrams but I'll need to know if your car is a MK1 or a MK2. 1997 might be either...
doobryfirkin
problem found and fixed, a wire on the rh brake indicater cluster was worn and shorting out.
thanks for all the help on the car side and on the grammer side
Tony :roll:
andmcit
x 30
Unread post by andmcit »
What a result! Great stuff.
Least with the original post you didn't stay stuck in caps lock!!!! :?
Andrew
Xantidote
x 5
Unread post by Xantidote »
And a nice cheap solution - always a bonus :D
Martin
1995 Xantia TDLX (deceased :( )
doobryfirkin
MoT on friday fingers crossed she will pass
Tony
Xaccers
x 186
doobryfirkin wrote:MoT on friday fingers crossed she will pass
Tony
If she doesn't, we'll be here ready to help :)
DIY sphere tool
doobryfirkin
:yeah: :clap: \:D/ :bd: she passed with only a advisery to check the rear brakes WOOOHOOO
Tony
