Lexia help
chic_scotland
Lexia help
I have chinese Lexia managed to get it up and running when I start the program it will recognise the car and give the correct vin number but when the office program opens it will not communicate any ideas I am tearing my hair out now any help appreciated
addo
- Sara Watson's Stalker
- x 95
chic_scotland
addo
- x 95
So you're getting to the part where it says "Please connect the Lexia interface to the PC and to the vehicle. Switch on the ignition" - yet after that it won't play nice?
Are you being prompted for the RPO number? What model of car? Is the OBD plug pressed all the way home?
Just to check - you are using the Lexia dongle, too - not just a generic OBD-USB connector with pirate software?
chic_scotland
addo
- x 95
Not 100% clear from your reply, but you are leaving the ignition switched on? That's essential.
As a side note, there's no demonstrable need to switch the key off and on every time it tells you to. I usually leave it on from the point just after I've selected the model.
The other thing to try is putting the Lexia on another car, this will reveal if it's a fault with your diagnostic socket or the computer bits.
paulbx
Lexia 3 works on C4 but not mk2 Xantia
I have similar issue works on C4 but not on Xantia mk2 - just does not recognize its connected.
Broomie(paulB) Xantia Hdi 90 estate
Sl4yer
chic_scotland
Update tried switching the Ignition on and leaving it on no change
Tried changing to C3R did not find the Vin
Although car is 2007 Reg it looks like a 2006 registered in 2007 it is a 1.4 petrol Desire
OBD Connecter is quite slack is that normal ? tried holding in different postions but no joy?
Will try to find a differnet Citroen to plug into but may take a few days
JamesQB
- x 5
chic_scotland
addo
- x 95
DHallworth
- x 173
chic_scotland
VertVega
- x 13
I have a similar one and it doesn't ask for RPO at all but happy with VIN onlychic_scotland wrote:Full Details
C3 2007
Lexia 437.18
Chinese Clone software
connects OK with Lexia finds the Vin Number then when the Office program opens get to Diagnosis check all switch ignition on then off no comunication
Just to make sure:
- Did you "Activate" it?
- Is it connected to USB 2.0 port?
