cooling fans - not cutting in
shaunthesheep
all, noticed today that my cooling fan is not cutting in at the correct temp, normally cuts in about 90
water level is fine, fuses are fine, temp gauge in car seems to be ging up/down.
did have a front end crunch with someone this week, but did'nt do any damaged to my car, but now i'm beinging to think otherwise.
could the above accdent be the result of the fans not working?
any replys would be good, will be taking off the bumper this weekend to have a good look.
dom
p.s. have also noticed that one of the pipes has broken off the charcoal canister in the engine bay, might this also contrubte to the problem?
dom
sooty
The fans are normally controlled by a sensor in the radiator on one of its sides. Best check if you have dislodged the connection to the sensor when you had the bump or any damage to the wiring.
If everything is in place, you can do a simple test to check whether its the wiring or sensor failure.
Get a short piece of reasonable size cable approx 50/75mm long with the ends stripped back by approx. 5mm, then remove the connection plug from the sensor and push the ends of the wires in the two spade type connectors making a loop. Being sure they are not touching each other, switch the ignition on and if the fans start your wiring is OK, but a dud/faulty sensor is why your fans don't run as they should do.
Sooty
Sooty
shaunthesheep
alan s
- RIP 2010
- x 6
Just purge that air in your cooling system; I have seen a bit of air in there causing this syndrome on occasions.
What can happen is that an air lock forms in the region of the sensor switch. These switches will only work on contact with the actual hot fluid but seem reluctant to trigger in hot air, hence they don't trigger.
The air lock moves & allows the coolant through & you think all is well until one day right out of the blue, you smell something hot & when you stop at the next set of lights you see steam coming out from under the bonnet. An inspection shows water spurting out of some very inflated hoses due to the steam pressure in the system. A good thorough bleeding & the problem is solved, even though the local grease monkey has probably already booked the car in for a new head gasket & told you that the head may even be cracked, 'coz he's done so many before...CXs were past masters of the art of doing this to you. Also, check for any small leaks on the return side of the cooling system as often, this was where the air came from in the first place.[:p][}:)][B)]
Alan S [:D]
Alan S [:D]
shaunthesheep
alan s
- RIP 2010
- x 6
Dom,
I'm probably telling you something you already know, but always be sure to have the heater opened in the hottest setting when bleeding the coolant; air locks have a nasty habit of hiding in heater matrixs which is sometimes the reason the matrix fail due to the increased pressure more than corrosion.
Alan S
Alan S
algieuk
shaunthesheep
Jon
vanny
AndersDK
Vanny -
What's the problem fitting a new sensor in your rad ?
The sensor HAVE to sense the actual water temperature - approx opposite to the rad's hot water inlet.
You may DIY a pipe with sensor fitted - then insert this pipe in the rad's bottom hose - but then the sensor MUST have a lower cut-in temp.
vanny
Well i had to cut a sensor in half to plug up the hole, there is pretty much NO room between the rad and the alternator. Its a good job there isnt too much movement in the engine or id already have major problems. Any ideas what the cut in temp is for the na diesel BX? Probably gonna rewire the whole lot with a fail safe switch in the cab, once the wate temp sensor is hoked up and proven accurate!
algieuk
algieuk
AndersDK
Vanny -
The cooling spec on a N/A diesel :
Thermostat : opens at 82/fully open at 93
Fan sensor switch : Low cut-in 86-90/high cut-in 90-94
Panel warning : early 103-107/ emergency 110-114
All figures deg. Celcius.
The switch cut-in range is caused by the waxstat principle used in the sensors.
Any electronic (solid state/semiconductor) sensors may give way more welldefined cut-in temps - easy to find as RadioShack/Maplin kits - or DIY if you're in electronics. The sensor elements can readily be build/moulded into the original sensor housings.
You MUST use at least an industrial Class 2 (prooven 2% full scale accuracy) temp gauge when testing the actual temperatures on your engine/cooling system - never rely on standard car fittings.
