2008 C5 Suspension Fault
hdi_man
Unread post by hdi_man »
got a puncture repaired and now the car is flashing "Suspension Fault, max speed 55mph". The suspension will no longer raise or lower the car.
booked into dealers as still under warranty, anyone else seen this ????
x 5670
I think that this is related to jacking up the car without first raising the suspension to full height.
Perhaps the tyre repairer wasn't aware of this requirement.
Try doing a protracted set of Citroebics and see if that clears the fault.
hdi_man
well dealer called, car needs a new Strreing Rack and some pump !?!.....covered under warranty, car has only done 18k miles !!! :?
I am worried about future reliability now
birksy
Unread post by birksy »
have you not asked why the rack and pump are creating the fault?
Sometimes the solution has little to do with the problem. Sensors maybe?
hdi_man
will need to find out more, a new steering rack being fitted though. possibly this flagged up as suspension fault....sill bad for car thats only done 30k miles....
