Xantia heater blower power supply
rroast
Hi Problem - No power to heater blower fuse when engine is running, presumably this is fed by a relay, can anyone identify which? I am not quite as agile as I used to be so it would save me having to trace the circuit. Thanks PS Xantia 1.9TD Estate LX 1998
rroast
Problem has now cleared itself - although had not been working for the last week / 300 miles with the car being used daily. I suspect it could be the ignition switch? although power was to the fuse when the key was in the 3rd position but not when engine stared and key returned to 3rd position, will have to wait until fault re-appears to prove
