Is the engine identical? & if so, howcome theres such a difference in the horsepower, is it just electronic jigery pokery, or are the internals & turbos different?
Which engine is the most reliable, i've heard of injectors going along with turbo's?
How long should a clutch typically last for if driven by the usual idiots out on the roads, i know some modern cars clutches seem to be made of paper & about as beefed up, so not that uncommon to need replacing around the 50-60k mark, which tbh is a bit pathetic.
Are there any other areas that i need to check on any of these cars which may cause big bills if not spotted?
I do fancy having A/C, or does this cause more issues than its actually worth?
I have owned a x reg Clio S (1.4 8V), which was ace, good fun to drive, reasonably economical, decent turn of speed & nothing really went wrong in 3yrs & 50k of ownership & parts were cheap, so looking for something similar.
All help/advice gratefully rec'd, cheers
